Hi,
The issue with the program is that when I generate an electrical installation on the second floor and try to set up lighting controls, two problems occur. Firstly, the dashed lines connecting the light switches to the lamps are not visible on the second floor. Secondly, all these lines appear on the ground floor instead of being distributed across the correct floors. The same issue occurs when exporting the drawing to a PDF. All the lighting control elements from both floors are combined and shown on each floor, making the drawings unclear.
How can I / You sove this?
