Floor Planner 09/2021 Release Notes - 【General Features】 related updates
1.Update more pocket styles
2.Wall drawing tool supported wall angle setting
3.2D and 3D view added furniture positioning line, RCP added lighting positioning line
In the plane view, click on "View - 2D Positioning" on the top navigation bar to place the furniture precisely into the room on the plan.
In the 3D or Roam view, click on "View - 3D Positioning" on the top navigation bar to place the furniture precisely into the room with the guides showing the distance in the six directions to the surfaces of the room.
In the RCP view, click on "View - Lighting Positioning" on the top navigation bar to place the lamp precisely in the ceiling.
4.Restrictions on the size of "Floor Opening" and "Sunken Ground" are reduced
5.The baseboard can be applied to all rooms with one click
Switch to 3D or Roam view, click any wall, and switch on the "baseboard" option in the property bar on the right. After setting up a proper styler, you can click "Apply to walls in all rooms" below to easily apply the baseboard to all the rooms.
6."Replace Material" supports restore to the original material
7.Added "Sign Out" function in the design interface
8.New designs added the automatic save function
