How do I modify a room dimension?
Homestyler Official 26 August 2022
You can modify the room size by dragging on selected wall segment directly in 2D/plane view. For precise adjustment, you can enter your specific dimension in order to achieve your desired requirements.
If you can't change the width and length of the wall, try the following:
we need to display the dimensions of the wall as follows: View --> Display Settings --> Dimensions --> Wall Centerline/Wall Inner Face. (Methods as below)
0 6847 3
Comments(3)
peacefulguy forhonor 7 June 2022
What to do if I only can change sizes with moving mouse, I don't have specific dimension near the walls
4 Reply
how to change sizes?
1 Reply
SATISH THORAT 17 September 2022
same issue. cant see room dimensions.@ peacefulguy forhonor
