Individual Wall Locks
stephenscr24 1 October
Is there a way to lock individual walls? I'm trying to resize rooms from a image I imported. However, when I move a wall to resize it changes other rooms. I want to lock each room's walls as I resize. For example, when I resize the Master Bathroom (23') it also resizes the Master Bedroom (after I've already resized it from 14' 8" to 16') It changes the Master Bedroom back to 14' 8"..
323 2
Comments(2)
Grace Simmons 4 October
Making one room large will always make the adjacent room smaller. Your going to have to resize the 1st room and all the adjacent rooms to get the sizes required. Or you can change the thickness of a specific wall to create the required room size. Or you can use the square column to fill in any voids you may create while resizing rooms-just make sure that in the right side menu the "wall part" is checked so that any material applied will treat the resized column as part of the wall.
Rosa María Castelló 3 October
Un truco es dividir esa pared, ya se quedará independiente y si eso no funciona borras solo ese trozo de pared y ya puedes moverlo correctamente.
