Support invert selection command using the shortcut key (Command/Ctrl+i)
Homestyler Official 18 May
The invert selection function can improve the efficiency of model selection. Select one model in the modeling interface, press the shortcut key Command/Ctrl+i to select other unselected models, then you can do other operations to these models in batches.
0 673 0
