Call for Empty Room Template Design!
Homestyler Official 24 April 2023
Challenge Overview:
To make our community more interesting and offer users different room styles, we are launching a challenge for the design of empty room templates on our app. You can create your own favorite room that meets the challenge requirements, and if your room template is selected, we will label the creator's avatar & nickname within the room design and publish it on the app community for everyone to use. In addition, we will also provide membership and 4K renders as rewards for selected entries. Homestyler welcomes everyone to unleash their creativity and participate actively. Click here to submit designs.
Challenge Time:
2023.04.18-2023.06.18
Challenge Awards:
There will be no final selection after the end of this challenge, and evaluation will be carried out every Monday. Selected room template designs will be displayed for one week at the top of the challenge page on the web and in Homestyler app for other users to use.
At the same time, we will notify you through Inbox and award the creator with 10 points, 10 x 4k renders, and one month of Styler!
TherThe homestyler app will update a new room every Tuesday, if you are selected, please don't worry, we will publish the works to the homestyler app according to the order of submission timee is no limit to the number of entries or winners for this challenge. Everyone can submit multiple works, and rewards can be obtained every week. Let's participate in this challenge together!
How to participate:
Go to https://3d.homestyler.com/?preciseFP=true  to create an empty room template that meets the challenge requirements, and submit your room designs to this Challenge.
Challenge Requirements:
1.Room Creation
1)The number of spaces shall not exceed 3, and the partition walls shall not block the sight of each space
2) You need to set a project name for the project (this name shall be consistent with the empty room name)
3) There are no restrictions on room size, wall height, room style, and room type
2.Room Assets
1) 3D furniture models, floor lamps, ceiling lights, etc. cannot be placed in the room (plant models can be placed outside the room to increase the atmosphere of the room, and spotlights can be placed indoors to increase brightness)
2) Materials can be added to the walls, floors, ceilings and models created by Interior Modeling to reflect the style and characteristics of the room
3) Structural models (doors, windows, door openings, wall niches, etc.) can be added to the room
4) The room can be created using the functions of Customize Ceilling, Customize Wall, Customize Floor and Interior Modeling, but Tile Flooring cannot be used.
● It is necessary to group internal models of the same type. For example: Stairs and railings are two types, so you need to combine stairs and railings separately, not together. The user cannot change the handrail material individually.
3.Room Rendering
1) In the rendering interface, the final camera view of the rendered image needs to be saved
Method: Enter the rendering interface > adjust the appropriate viewing angle > click "Save Current View" at the bottom right
*Cannot render with camera clipping
2) A rendering with a ratio (2:1) and resolution (2k and above) needs to be submitted as the cover image, which will be displayed on Homestyler app later.
3) The camera angle of view of the rendering image shall be selected from the horizontal angle of view, please note that the upward/downward angle of view cannot be selected
4) The light in the room should not be overexposed/too dark, please ensure that the brightness of the light source in the room is normal
Creation Showcase:
In the process of creation, it can be made from outdoor, indoor, courtyard and other spaces. The following images are sourced from Pinterest:
At the same time, you can also check the room templates in Homestyler app to understand the creation direction:
FAQ:
1. Where will the selected room template designs be displayed?
Firstly, please download Homestyler App. On our App's "Design" page, click "Start with Room Template to Design" and you can see the selected design. Click on the cover to view the design name and creator avatar & nickname. You can also click on the creator's avatar to enter his/her personal homepage.
2. How can I check if my design is selected and used in Homestyler app
After the design is selected, we will pin the selected design at the top of the challenge page on the web for a week (update the pinned design at the top every Monday), and once the design is added to our app, we will notify you and send you awards via Inbox.(
3.If my Homestyler account is canceled, will the selected designs still be displayed in Homestyler App?
Yes, please kindly note that after the account is canceled, we will not be able to see your personal information, and the creator's avatar & nickname after opening the room template will indicate Homestyler official account. As shown below:
4.My room is selected, but why isn't it showing in the homestyler app?
The homestyler app will update a new room every Tuesday, if you are selected, please don't worry, we will publish the works to the homestyler app in the order of submission time.
0 8872 26
Comments(26)
We have not limited the number of winners for this challenge. We will issue rewards for all selected projects.@ RAN'S INTERIORS
Hi Homestyler staff! How many winners will be chosen every week for this contest? Thank you :)
4 Reply
Rebecca Laghi 18 April 2023
In Challenge Requirement number 1 (1.Room Creationt the number of spaces shall not exceed 3, and the partition walls shall not block the sight of each space...) - the pic for example isn't it:
2 Reply
decor design 28 June
For an empty room template design, consider the following suggestions: Start with a focal point: Choose a standout feature like a statement wall, fireplace, or prominent piece of furniture. Optimize lighting: Incorporate both natural and artificial lighting to create a bright and inviting space. Use a combination of ceiling lights, floor lamps, and task lighting. Select a color scheme: Choose colors that complement each other and align with the desired mood. Consider using neutral tones as a base and adding pops of color through accessories.
1 Reply
Homestyler Official 22 May
The following are the works that were selected this week (May15-22). Designer Name:Hybrid Interiors https://www.homestyler.com/projectDetail/6464dc8db22e140eb95c3ae8 Designer Name:Ana Paula Castro: https://www.homestyler.com/projectDetail/64665b9d4c12ba0c309d1d07
1 Reply
Homestyler Official 16 May
The following are the works that were selected this week May (8-15). Designer Name:Hybrid Interiors Project Link:https://www.homestyler.com/projectDetail/6456c862573b7c099eca03d7 Project Link:https://www.homestyler.com/projectDetail/6459a93f573b7c099eca28af
1 Reply
The following are the works that were selected this week (April 18-24). Designer Name:denise_hl Project Link:https://www.homestyler.com/projectDetail/64401ea3573b7c099ec8bfab Designer Name:Ran Interiors Project Link:https://www.homestyler.com/projectDetail/6445b3314c12ba0b31ee5ee9 Designer Name:Ran Interiors Project Link:https://www.homestyler.com/projectDetail/6441f2614c12ba0b31ee333e
1 Reply
Grace Simmons 23 April 2023
Why not make room templates available for web designers????? @homestyler
1 Reply
RAN'S INTERIORS 23 April 2023
1 Reply
Grace Simmons 19 April 2023
🤣 The 'Homestyler' room example on the challenge page is set to private!!!!
1 Reply
Marina Bruna 4 July
Hola!! Se que mi diseño fue elegido para el Desafío de Plantilla Vacía, aparece en el listado arriba y me dieron 1 mes de STYLER el 26/06, pero no me dieron los Renders 4K ni los 10 puntos. Me pueden aclarar cual es problema? Muchas gracias!!
ROBERTA GIULIETTI 2 July
HS, When will the winners be decided?
Homestyler Official 26 June
The following are the works selected for this week: Designer:Gob . Design Link:https://www.homestyler.com/projectDetail/648baab1b22e140bfbec983f Designer:Marine _ Design Link:https://www.homestyler.com/projectDetail/648deed94c12ba0c0f776585 Designer:Marina Bruna Design Link:https://www.homestyler.com/projectDetail/648d0985b22e140bfbeca743 Designer:Ran's Interiors Design Link:https://www.homestyler.com/projectDetail/648928f3b22e140bfbec7813 Design Link:https://www.homestyler.com/projectDetail/64749fd0b22e140bfbeb76a6
Jackson Richard 7 June
Great article on design! The section on color palettes was enlightening. Thanks for the inspiring read! By the way, if you're looking for stunning granite countertops, check out Granite4Less. We offer a wide range of high-quality options in Montreal to elevate your kitchen's style. Give us a Visit at https://granite4less.ca/indexe
Homestyler support 6 June
The following are the works selected for this week (May 30-June 6): Designer:@happyplace @home Design Link:https://www.homestyler.com/projectDetail/644008b44c12ba0b31ee122f Designer:bengisuabayli Design Link:https://www.homestyler.com/projectDetail/6440df9a4c12ba0b31ee1ee5 Designer:bengisuabayli Design Link:https://www.homestyler.com/projectDetail/646f617f4c12ba0c6c075d86 Designer:Hybrid Interiors Design Link:Design Link:https://www.homestyler.com/projectDetail/6467eb724c12ba0c309d3584 Designer:Ilaria Cartoni https://www.homestyler.com/projectDetail/644a4f754c12ba0b31eea98b
Carmen Diana Almeida Eleno 1 June
This is such a great idea! I love decorating with Home Styler, but I'm not that good with the architecture tools. Will the rooms be open to decorate for other users like me? How many will be uploaded? The designs are just so wonderful I would like to decorate all of them!
chrisjonesv12 30 May
A wonderful article about design! I'm amazed at how the author thoroughly explores various aspects of the design process. I was particularly impressed by the section on the impact of color palettes on emotional perception. I now have a better understanding of how to choose appropriate colors for my projects. Thank you for the informative and inspiring read)
Homestyler Official 29 May
The following are the works that were selected this week (May122-29). Designer Name:Ilaria Cartoni Designer Link:https://www.homestyler.com/projectDetail/644a4f754c12ba0b31eea98b
JADYNN YATES 18 May
I'm making my dream house
Grace Simmons 9 May
I'm confused. Re-read the forum page for this contest. Went looking for the room templates but couldn't find them. So I guess this was only for App users. Even though the challenge page says that the tool to be used is the web. Not happy that Web users can't access these designs.
Homestyler Official 8 May
The following are the works that were selected this week (May 1-8). Designer Name:anjaa mmm Project Link:https://www.homestyler.com/projectDetail/64406107573b7c099ec8c5ab Designer Name:Sc Arquitetura Project Link:https://www.homestyler.com/projectDetail/644040054c12ba0b31ee1886 Designer Name:Sofia Grimaldi Project Link:https://www.homestyler.com/projectDetail/6448f7d1573b7c099ec93c6b
Asim Azeem 2 May
This is most intresting topic here. I would like to say that everyone can take care of there furniture and make there bedrooms and lounges beautifull. I have the vast range of wooden furniture. Visit Us: https://cashandcarrybeds.com/
RAN'S INTERIORS 28 April 2023
Will second place room template also be able to be designed with?@ Homestyler Official
The room selected on Monday has already been used by many people on the app. From the link, you can see that many people are designing in the selected room. You can also download the homestyler app to try it out!(link:https://www.homestyler.com/challenge/11387-Weekly%20Room-Sunset%20Empty%20Room?spm=a1zmxy.27273860.0.0.25281e49ONesi0) PS: Every Tuesday, we will launch a room design challenge on the app. The selected room will become the object of creation, only change the material of the walls and floors, and create with furniture.
Homestyler Official 27 April 2023
Ryann Greene 26 April 2023
ok
zaydenwood42 22 April 2023
With modern home decor ideas you can make an entire space can feel fresh. Transform your property into a modern family home with My Home Handyman exterior and interior renovation ideas.@ Rebecca Laghi
Homestyler Official 19 April 2023
Thanks for the reminder, corrected.@ Grace Simmons
