How to Improve the Success Rate of Importing CAD Files
Homestyler Official 5 March 2023
1. Check whether the file format is correct
Support DWG and DXF files drawn by AutoCAD
2. Check whether the file size is larger than 10M
There may be hidden layers, blocks, etc. in the file that cause the file to be too large. Once the file is more than 10M, it will fail to import.
Solution:
1) Enter CAD, use wblock command, select the floor plan to be imported, save it as a new DWG drawing and then import it.
2) You can also create a new drawing, copy the floor plan to be imported, save it and import it again.
3. Check whether the file contains too many complex graphics
If there are too many drawings in the file or there are too many complex graphics in the drawing, it will cause the drawing import to fail.
Solution:
Remove useless information in CAD, only keep the floor plan and import again.
4. Check whether the wall line in the file is drawn with double lines
For the time being, Homestyler only supports the recognition of double-line walls. If a single-line drawing is used, it will cause the drawing import to fail.
0 16130 11
Comments(11)
gatyhamra 3 September
i cant uploaded dwg file
12 Reply
Monika Miteva 2 July
hi, my file is correct, why is the system not allowing me to continue?
10 Reply
vn-vas 9 April 2023
floorplandiskill.dwg
3 Reply
d3m3 31 March
A few days ago and still the same problem? There is no solution and our subscription will be useless
2 Reply
constructioneternelle 18 April 2023
hi did this files can be support. If not is there a way to make it ? thanks Benjamin
1 Reply
Nitin Agari 2 April
file no open
Светла Горбунова 30 March
dosen`t work yet?
Yosif Ayman 17 March
its unknown problem when i uploading a DWG file to the site .. i think i did all right
Mawaa Ahmed 10 March
the import file does not open with me.
Sherin Issa 22 November
Did you figure out why it wasn't letting you? Cause I'm having the same problem.@ Monika Miteva
Hranush Sahakyan 20 November
