Hi everyone, I've been going crazy on this problem for several days, I would be grateful if you could help me. I have created a building with several floors, and from the outside I see a space between one floor and another. How do I take it off? Thank you so much
It may seem like a lot of work but if your really passionate about the design then it will be worth it. Saving your furniture as a group helps cut down the time you would spend looking thru the inventory all over again. Same goes for wall/floor materials. If you took 1K renders the pictures will still be in the image file--its a great reference for what you have already done. Never ever delete a design unless you are absolutely sure you won't need it, I learned that lesson the hard way. Good luck
