If you have an ED problem and are looking for a pill that can help you get an erection, Cenforce 100 is a good choice for you. It is made up of Sildenafil, a substance that is known for its ability to reduce the action of phosphodiesterase type-5. Sildenafil is also an anti-inflammatory drug, meaning that it helps increase blood flow during erections.
Sildenafil, the active ingredient in Cenforce 100 usa, is a prescription medicine that can help cure ED problems. It works by lowering blood pressure.
Sildenafil starts to work in your body within half an hour. It may take longer to be effective if you are a larger person. However, it will still work to improve your erection. The full effect lasts for between two and six hours.
