Terrace
Isabelle C 24 September 2022
I'm just wondering how to make a terrace in this game, i was just trying to make one and noticed that i just could'nt do so
0 461 4
Comments(4)
Grace Simmons 24 September 2022
There are several ways...create your floor plan-making a room that you want as a terrace. In plane view: click on wall and on right side menu choose partial and change the height of the wall. You can go as low as 4" and then put in a railing or change to 3' and use the walls as is. Then click on the same room and change the show ceiling option. If this is a multi story design: go to the upper floor and in plane view, choose the room over the designated for terrace and then in right side menu choose edit floor. Remove the floor, then go back to lower floor and change wall height.
2 Reply
Ali Ortiz 27 July
Wait how do I change the walls to put a railing instead?? Btw thanks for the other info, super helpfull.@ Grace Simmons
H DFH 25 September 2022
The Information you shared above is great. https://newjerseyloteryresults.com/ I have been reading all you shared here. In this you explained everything very well. If i want any further guideline we will contact you here. Thanks
You can check out HS YouTube channel or put 'Homestyler' in search bar for tutorials. Or you can check out the tutorials under the learn tab of the site. This video: https://www.youtube.com/watch?v=PbnXBmeYXYs&t=1000s.....is kind of an overall look at what you ca do. This is a basic one for editing floors: https://www.youtube.com/watch?v=OVtSta5W4-4&t=5s.....Good Luck!!
