Hi I would like to create an option layout for a client and I wonder if I can copy the original file into a new one there I can make ajastaments.
Top menu> save> save as.....It will save the original design as a 'copy of xxxx' or a name you give it. Then make the adjustments and save. You can then save the 2nd --the same way and make another set of adjustments.
