Is there a way to rotate an entire plan by 90 degrees for example
Hi,
i struggled with the same problem.
Finally came the big light....use the NORTH sign at the left upper corner. That is the solution. The sign can be rotated by 90 degrees. Not user friendly, but I could turn it by 90 deg.
Marianna
