In the Custom Furniture interface, when you design you could select the custom model and edit it individually with detailed parameters of each board. Just select the model, select "Edit" from the arrow at the end, and you can enter the editing interface. In the editing interface, you can also modify the detailed size or material properties of the model.
Как потом выйти из детального редактирования?
