How to render a normal image?
To render a normal image, simply switch to "Normal" from the top. After setting up the "Resolution", "Aspect Ratio", and "Lighting" of the image you need to render, with the camera view adjusted by directly dragging in the central window or adjusting the camera settings on the right, just click "Render" below to submit the rendering. After which, click on "Images" from the upper right corner and you can find the rendering progress and the final renders in the album.如何创建普通图.gif
0 1984 0
