Added 540p and you can spend points for it,and more
Floor Planner 08/2021 Release Notes - 【Video Render】 related updates
1.Video resolution added 540p and you can spend Homestyler points for it
2.Support directly drawing curved path and straight path
3.Video rendering added advanced mode
Detailed tutorial :
4.The lamps support brightness change animation in video
0 2023 1
Comments(1)
saba saremi 2 January
Hi, I've started rendering an animation for myself, but it's been almost 4 hours and there's still no output. Why does it take so long to render an animation?
