Support precise model rotation,and more
Floor Planner 12/2021 Release Notes - 【General Features】 related updates
1.Support precise model rotation
2.Supported applying the current material to the same doors/windows.
3.Supported applying the elevation height to the same doors/windows.
After placing the window/door, first adjust the elevation height of a certain window from the ground.
The system will prompt you whether you want to apply the height to other windows with one click, if yes, just click "Apply".
4.Supported continuous duplication of door and window models.
5.The Measure tool supported display multiple measurement size.
6.Added update log link in the design interface.
2977 0
