Click "Customize-Interior Modeling 2.0" and select the room to enter the Interior Modeling 2.0 interface. Select the 3D text in the left "Assembly-3D Text" catalog, click to select the surface you need to place the 3D text, and then type in the text. You can change the font or edit the text in the "Parameter Settings" from the right property panel. You can also change the size and thickness of the text in the "Position" section.
add txt arabic please
