How to adjust the parameters of the cabinet and door?
For each custom model, select the model and you can adjust the parameters on the right. You could also double-click to enter a model and select each panel and board. Similarly, when selecting a part, you could adjust its parameter on the right property panel as well.
0 2153 7
Comments(7)
Design Project 12 April 2022
How can I remove handles from cabinets? Can you solve this problem?
1 Reply
Lilia Mihalcova 15 February 2023
Добрый день, я не могу добавить на сцену поместить объекты из раздела Custom Furniture, в чем проблема, подскажите пожалуйста.
Design Project 19 April 2022
Unfortunately, the program does not allow you to completely remove the handles on the doors. Do you have an opportunity to fix this in furniture modeling?
Teke Tin Tekes 1 March 2022
Is anyone else having problems changing the material on the cabinets? No matter what I do, the material will not change.
hodo kaise 22 February 2022
can i edit models ?
Homestyler Official 11 February 2022
You could find them in the catalog under "kitchen", check ou the screenshot below:@ carrie.yoshida
How do I access library of appliances (refrigerator, stove, dish washer, wine refrigerator)?
carrie.yoshida 10 February 2022
