V4.0.2-Added customize ceilings, walls, floors, and more
Homestyler Official 19 May 2023
1.【General Features】
1.1【Function】Wall drawing tool supported wall angle setting
1.2【Function】2D and 3D view added furniture positioning line, RCP added lighting positioning line
1.3【Function】Restrictions on the size of "Floor Opening" and "Sunken Ground" are reduced.
1.4【Function】The baseboard can be applied to all rooms with one click
1.5【Function】Added multiple Door Pocket
1.6【Function】"Replace Material" supports restore to the original material
1.7【Function】Added "Sign Out" function in the design interface
1.8【Function】New designs added the automatic save function
2.【Full house furnishing】
2.1【Full house furnishing】Added a new smart "Customize Ceiling" function
2.2【Full house furnishing】Added professional "Customize Wall "function
2.3【Full house furnishing】Added free "Customize Floor" function
2.4【Full house furnishing】“Tile Flooring”Added Guide Lines function
3.【Interior Modeling 2.0】
3.1【Interior Modeling 2.0】Added“3D Fillet” function
3.2【Interior Modeling 2.0】Added“Revolve” function
3.3【Interior Modeling 2.0】Custom models in My Favorite supported renaming
4.【Rendering】
4.1【Render】Supported Batch Watermark Removal(Member Exclusive)
4.2【Render】Render editor supports "depth of field effect"(Member Exclusive)
4.3【Render】Normal pictures added Auxilary lines
4.4【Render】Added 15 kinds of "Spot Light"
4.6【Render】Added opening animation to panorama
Detailed Introduction:
1.8 【Function】New designs added the automatic save function
Pitched, gabled, or grid ceiling? Apply Parametric Ceiling with Simply One Click!
Detailed tutorial:https://www.homestyler.com/blog/1301?spm
The new "Customize Wall" function allows you to focus on the designated wall and improves wall decoration efficiency. We have also added more decorative moldings and you could drag to decorate your walls.
According to your design requirements, the new "Customize Floor" function allows you to focus on the designated floor. Simply draw shapes, extrude and then you could easily create a floor platform, stacked stairs, or other floor structure.
Enter "Tile Flooring" and then click "Guide Lines-Add Guide Lines", left-click on any side on the canvas, enter the specific distance value, and you can get the precise guides as a reference to draw.
4.【Rendering】
7130 0
