How to design the outside area?
You can choose the following two ways to design:
1. You could draw a room as the garden, select the wall in the plane view, adjust the height of the wall in the "Basic Parameters-Partial" on the right panel, and then lower the wall height as the fence.
You could also select "Outside Area" in the "Create Room" section to draw an external area on the canvas. After drawing, you can select the ground for material replacement.
0 10184 5
Comments(5)
Andrea Harmina 5 November 2022
after external area created - partial the wall - how can I remove-delete the roof??
13 Reply
Туйаара Федорова 6 June 2022
How do I increase the outside area size, than 100*100 meters?
8 Reply
Anabella Bustamante 23 August 2022
te respondieron? como hacerlo?@ brooklyn kingi
how do i place the grass down
2 Reply
Irina Datcu 4 October
Hi, if I use OUTSIDE area to create the yard, what exactly do I need to do? there is any trick because I try ro draw but it doesn't really work. I've managed to do an small area BY MISTAKE but if I want to select the correct area that i need is not working
brooklyn kingi 3 August 2022
