Why does my render come out so dark?
Please check whether you have openings on your wall and whether the room has light sources. You could also choose a pre-set lighting template or customize your own lighting. Also please check whether your camera is in the wall from the window inn the upper right corner.
0 3280 4
Comments(4)
Jose Miranda Chavez 23 May
fghkjfvveu fvbhfbvandfnbrnsgfvbrgfvjncjb
allora interiores Louise 4 May
Why I never get an answer on my search in model library? Always, not found...
intermonic 18 October 2022
Como vuelvo al menu general despues de editar un mueble
Julio Lop 31 March 2022
Porque mi render queda de esta manera? con otro proyecto no tengo problema, pero con el diseño de este proyecto si.
