Register Now & Get a $19 Welcome Gift!
Problem with creating a floor
Alina Veselova12 October
Hello, I faced with a problem: can't make a floor, all the walls are made.
Could you plese help me? Many thanks.
Best regards Alina
0 41 1
Comments(1)
Grace Simmons13 October
In this diagram, looks like floors aren't showing because the walls aren't connected. Its a HS thing! Close the wall on the left and use a 'wall opening' to make opening/pathway. OR leave it as is and use custom modeling to make the floor. If the plan is not finished.....close the wall, finish the floor plan and then split walls/delete walls as desired. The whole plan must have continuous closed outside walls. If the opening is for a door, close the wall and then put the door in. The perimeter walls must be closed to get the floor. Hope this helps.
