thanks for your answer, i try option 1(select one model from the “Environment” catalog, and then replace its material with your own image) but when i render it was blank
@ Homestyler Official
Hi you could either 1. select one model from the “Environment” catalog, and then replace its material with your own image uploaded. OR 2. You could go to render interface, and then in the left panel where you could choose outside environment, you could upload your own.
Respuesta
Reserve una demostración gratuita y hable con nuestro departamento de ventas
Las empresas líderes mundiales confían en Homestyler
